One of the cooling fan automatic control circuits
Source: InternetPublisher:通通 Keywords: Fan BSP Updated: 2021/12/15
When the temperature reaches the upper limit (for example, 850C for a power transformer), contacts 1 and 2 of the electric contact pressure thermometer
KP are connected, relay KA is closed, and the fan runs. When the temperature drops to the lower limit (65°C),
2-3 of KP are turned on, KA is released, and the fan stops running.
Since the contact of KP does not directly start the relay, but controls the base circuit of the triode, it can avoid
sparks and singeing of the contacts.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- Hot wire spark plug control circuit
- How to design a health emergency alert device using MPU6050
- Smart Farm Design Solution Based on LoRa
- How to build a self-driving drone
- How to build an electric vehicle EV charger
- Electric massager circuit
- JS13 type transistor time relay circuit
- Commonly used oil pump motor control circuits for presses
- One use and one standby constant pressure water supply frequency conversion speed control circuit b
- Egg warming circuit
- Particle clogging alarm circuit of wheat seeder
- Greenhouse temperature control circuit
- Farmland drainage automatic control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Wien bridge oscillator circuit
- Schiller oscillator circuit
- Power phase sequence display circuit
- Sawtooth wave generator circuit (2)
- Sine wave signal generator circuit
