Digital power circuit diagram
Source: InternetPublisher:小胖友 Keywords: Digital power supply LM338 Updated: 2024/03/29
Digital power circuit diagram (1)
Below is a digital power supply circuit based on LM338, the diagram below allows to obtain the necessary output voltage level using a digital signal supplied to the base of the transistor . The size of each resistor in the transistor's collector circuit is chosen based on the desired output voltage.
Digital power circuit diagram (2)
Below is a digital adjustable power supply circuit based on LM338 , the design given below incorporates discrete transistors which can be individually digitally triggered to obtain the relevant voltage levels at the output. The collector resistance values are selected in increasing order so that a correspondingly varying voltage can be selected and made available via an external trigger.
Digital power circuit diagram (3)
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Energy-saving motorcycle rectifier regulator
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- ISO113 circuit that can reduce power consumption
- Simple and practical LED lamp driving circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Adjustable regulated power supply with current limiting protection
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Switching power supply circuit composition and detailed explanation of each part (1)
- Design of adjustable DC stabilized power supply circuit module
- 24V power supply pure flat display high voltage power supply circuit diagram
- DC 12V to AC 100V inverter power supply circuit design
- Laser power circuit
- EPSON PHOTO 830U printer power circuit
- led drive power circuit
- Common power circuits and applications 04
- AC-DC conversion power supply-inverter power supply circuit
- CTX-C2 dual-band high-resolution color display power circuit
