Buck switching regulator circuit diagram explained
Source: InternetPublisher:吃掉星星 Keywords: Voltage regulator circuit buck switch LM2678 Updated: 2024/03/27
Buck switching regulator circuit diagram (1)
This is a circuit diagram based on the LM2678 step-down switching regulator. The LM2678 series of voltage regulators are monolithic integrated circuits that provide all the necessary functions required for a step-down switching regulator and can drive loads up to 5A. The IC has over 90% efficiency and excellent load and line regulation. The LM2678 is available in three fixed output voltages (3.3V, 5V, 12V) and an adjustable output version. The IC also has few features such as thermal shutdown, current limit and ON/OFF control.
The circuit given here is based on the LM2678-5.0 version, which provides a 5V output. The input voltage of the regulator is fed to pin 2 of the IC. Capacitors C1 to C4 are input bypass capacitors. They also provide current to the IC controlled switch when it is first turned on . Capacitor C5 boosts the gate drive of the internal MOSFET , causing it to fully conduct. This minimizes switching losses and helps achieve high efficiency. Pin 7 is the ON/OFF pin, if this pin is connected to ground, the regulator will shut down. The current consumption in shutdown mode will be less than 50uA. Schottky diode D1 is used as a freewheeling diode. When the control switch (internal MOSFET) is closed, the current in the inductor L1 flows through this diode. capacitors C6 and C7 and the output filter capacitor.
Assemble the circuit on a high quality PCB .
The circuit's power supply can be anything between 8 and 40V DC .
The feedback wiring must be as far away from inductor L1 as possible.
Do not use loads that consume more than 5A.
It is highly recommended to use a heat sink for the IC.
Buck switching regulator circuit diagram (2)
As the name suggests, a Buck-type step-down switching regulator means that the input voltage is higher than the output voltage. The conversion principle is shown in the figure below:
①Detect the output voltage and compare it with the reference voltage
②When the output voltage is lower than the set output voltage, the switch is ON and the current flows in the direction of the red arrow.
③Inductor stores magnetic energy
④When the output voltage is higher than the set output voltage, the switch is OFF and the current flows in the direction of the green arrow.
⑤The inductor converts the stored magnetic energy into current for load output, and then returns to the inductor
⑥When the magnetic energy of the inductor disappears and the output voltage begins to drop, the switch will turn ON again.
By controlling the turn-off and turn-on time of the switch tube, a stable output voltage can be obtained.
Synchronous rectification or asynchronous rectification
In the Buck circuit, only one power tube is asynchronous. The asynchronous type relies on the freewheeling of the diode to complete the green area in the picture above. Synchronous rectification has two power tubes, generally called upper tube and lower tube. These two tubes are controlled by a logic device, and only one tube is in the conducting state at the same time.
Characteristics of non-synchronous rectification
Low efficiency, especially when the load is large current
Simple circuit and low cost
Synchronous rectification characteristics
High efficiency, MOS tube conduction internal resistance is very small
Requires additional control circuitry and costs more
Working modeCCMDCMBCM
CCM (Conti nuousConductionMode ) continuous conduction mode: the inductor current is always greater than zero during a switching cycle
DCM (DisontinuousConductionMode) discontinuous conduction mode: the inductor current will return to zero within a switching cycle
BCM (BoundaryConductionMode) critical conduction mode: the minimum value of the inductor current just returns to zero within a switching cycle
It is different for synchronous and asynchronous structures. The use of diode freewheeling in the asynchronous structure can prevent the direction of the inductor current from falling below 0. For the synchronous structure, MOS tubes are used instead of diodes. MOS tubes can allow the inductor current to reverse direction, that is, flow out of the load, causing the inductor current to be below 0.
In actual application scenarios, most DCDCs work in CCM.
- Analysis of the working principle of switching regulator
- Benefits of Wide Bandgap Technology for Power Converters
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Energy-saving motorcycle rectifier regulator
- Simple and practical LED lamp driving circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Detailed explanation of 5v charger circuit diagram
- Adjustable regulated power supply with current limiting protection
- Converting a lithium battery charging board into a constant voltage and current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Power circuit of STR5412
- DC 12V to AC 100V inverter power supply circuit design
- Typical Reference Voltage and Power Supply Circuits
- Output 12V-10A power supply circuit
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Simple dual-channel variable DC power supply circuit
- Telephone power circuit
- CTX-C2 dual-band high-resolution color display power circuit
