Tutorial on using 8051 microcontroller to display content on LCD screen
Source: InternetPublisher:抄写员 Keywords: Liquid crystal display LCD microcontroller Updated: 2025/02/14
Liquid Crystal Display (LCD) is a commonly used display screen that is often used in many electronic products to display information in text or image format. LCD is used to display characters such as letters, numbers, etc. on its screen. LCD display consists of 8 data lines and 3 control lines, which are used to connect LCD display with 8051 microcontroller.
Consider using Proteus based analog LCD to interface with 8051 microcontroller:
How to display "8051 microcontroller" on the LCD display, the case program is as follows:
#include< reg51.h >#define kam P0void lcd_initi(); void lcd_dat(unsigned char ); void lcd_cmd(unsigned char ); void delay(); void display(unsigned char *s, unsigned char r) sbit rs=P2^0; sbit rw=P2^1; sbit en=P2^2; void main(){ lcd_initi(); lcd_cmd(0x80); delay(100); lcd_cmd(0xc0); display("8051 MCU",10); while(1); } void display(unsigned char *s, unsigned char r){ unsignedint w; for(w=0;w<r;w++) { lcd_data(s[w]); } } void lcd_initi() { lcd_cmd(0x01); delay(100); lcd_cmd(0x38); delay(100); lcd_cmd(0x06); delay(100); lcd_cmd(0x0c); delay(100); } voidlcd_dat(unsigned char dat) { kam = dat; rs=1; rw=0; en=1; delay(100); en=0; } } voidlcd_cmd(unsigned char cmd) { kam=cmd; rs=0; rw=0; en=1; delay(100); en=0; } void delay( unsigned int n){ unsignedint a; for(a=0;a<n;a++);}
- Make an alcohol tester based on 8051 microcontroller
- Homemade bidirectional reversible length measuring device for rubber tubes
- Application circuit of CSJ-R05B and single chip microcomputer
- SN75370 Dual MOS Memory Interface Circuit
- Sample and hold amplifier AD9101 interface circuit
- How to design an AirPlay speaker using Raspberry Pi Zero
- How to make a BLE-enabled smart light bulb using STM32
- How to design an ESP32-based microcontroller development board
- How to use ADXL335 to realize the design of gesture control robot
- Experiment on using 51 microcontroller to drive relay
- Design of temperature detection circuit implemented by single chip microcomputer
- Dual audio decoding electronic circuit
- SPI interface and microcontroller interface principle circuit diagram
- Minimum system interface circuit based on AT89C52 microcontroller
- IR2130 combined with microcontroller and SLE4520 for three-phase frequency conversion system diagram
- MAX16834 driver LED circuit diagram
- Microcontroller speech synthesis integrated circuit HM2068 manual operation mode application circuit
- Bicycle measuring meter circuit using EPSON microcontroller
- SMC62T3 microcontroller basic line connection
- The P1 port of 8031 microcontroller constitutes a 4X4 keyboard interface circuit
