SN75370 Dual MOS Memory Interface Circuit
Source: InternetPublisher:红水杯 Keywords: Memory Interface Circuit Updated: 2024/08/29
SN75370 is a monolithic integrated read/write interface circuit that can be used for the input/output interface between 4062 and similar MOS RAM and TTL circuits. It can directly interface with the I/O of MOS RAMs such as 4062. During write operation, the driver can provide a complementary high voltage output, with high sensitivity in read operation, TTL and DTL compatible diode clamp input, TTL and DTL compatible data output, data output terminal can be connected as "AND", and the power supply voltage range is large. The figure shows the interconnection diagram of SN75370 and 4062.
- Are more bits in an MCU better?
- Commonly used MCU reset circuit sharing
- Make an Interactive Arcade Bedside Clock
- Application circuit of CSJ-R05B and single chip microcomputer
- Interface circuit composed of 8255A and single chip microcomputer
- Interface circuit between intelligent temperature sensor TCN75 with two-wire serial interface and 89C51 single-chip microcomputer
- How to use ESP8266 to make a mini fully functional clock
- How to control fans using LM35 and ATTiny13
- A safe and reliable IC card reader/writer system circuit
- Circuit diagram: 8515 extended RAM
- Minimum system interface circuit based on AT89C52 microcontroller
- FM24C256 interface circuit
- Interface circuit of card reading module
- Alarm interface circuit
- MAX233-233A multi-channel data interface circuit
- MAX230 multi-channel data interface circuit
- Interface circuit for automatic counting using electronic counter b
- Interface circuit between CMOS and NMOS a
- Interface circuit between power supply coupler and PLC
- Power supply coupler-thyristor interface circuit a
