Low power consumption timing switch circuit
Source: InternetPublisher:spectrum Keywords: Low power consumption switching circuit timing switch BSP Updated: 2021/01/03
(I) Introduction to the circuit principle: This timing circuit is equipped with an electronic switch composed of F1, F2 and VT1, which can
reduce the quiescent current of the 555 to 1-2riA. When the power is first turned on, the voltage on G cannot change suddenly, causing the F2 gate circuit to be at a high level and the Fl output to be locked at a low level
. VT1 is cut off, making the quiescent
current of the entire circuit very small. When the timer switch AN is pressed.
A negative polarity pulse appears at the input terminal of Fl.
Fl output is high level, VT is turned on, and 555
has power supply voltage. At the same time, a negative pulse is
applied to the ② pin of 555 to set the 555. K
pulls in and the timing starts. Timing time Td—
1. lR4 C3. The timing length can be changed by adjusting
the time constant of Shuc{.
(2) Component parameter selection
The selection of components is shown in Figure 3-44, and there are no special requirements.
(3) The low-power timing switch circuit is shown in Figure
3-44.
- How to choose the right level of integration to meet motor design requirements?
- Car ice warning circuit sharing
- Motor automatic cycle control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Using P110C to control 6 DC motors simultaneously
- Design and principle analysis of practical electric curtain remote control device
- Design and production of radio remote control fan stepless speed regulator
- Magnetic door and window anti-theft alarm
- Home wireless burglar alarm circuit
- Homemade anti-theft watchdog
- strain sensor
- Electric massager circuit
- Inpatient pager circuit
- Egg warming circuit
- ring amplitude modulation circuit
- Inductive feedback oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Three primary color display circuit
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (1)
