Set timing circuit when power is on
Source: InternetPublisher:zht24 Keywords: Power supply timing circuit BSP pulse Updated: 2021/08/29
(1) Introduction to the circuit principle. Figure 3-42 shows the set timing circuit when the power is turned on. When the power is turned on, within
the time , the trigger level of pin ② of NE555 is lower than ( 1/3)
Ur, ③ pin output pulse . Then. +Ucc
charges C2 via R and VD1, and the charging voltage rises to close to
+Ucc:. Due to the isolation effect of VD1, it does not affect the
negative
trigger pulse differentiated by R, and C used during normal operation. VD1 is a diode used to quickly
discharge 0 when the power is turned off. Even if the power supply is repeatedly turned on and
off for a short period of time, it can ensure reliable operation of the circuit. The high level of
the NE555 output pulse T is determined by R3 and G
, that is, T-Y C3.
(2) Component parameter selection The selection of components is
shown in Figure 3-42. There are no special requirements.
(3) The set timing circuit when the power is turned on is shown in Figure 3-42
- The meaning and importance of circuit protection, common types of circuit protection
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- DC motor drive circuit composed of L293D
- Working principle of one Xipu STR soft starter controlling two motors
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Add one more component to improve the phase failure protection function
- Hydraulic control circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Bicycle anti-theft alarm
- Motor forward and reverse control wiring diagram (2)
- soil content measurement circuit
- High-efficiency speaker circuit for rural stage
- Farmland drainage automatic control circuit
- Mixer built with analog multipliers
- OTL low frequency power amplifier circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- color discrimination circuit
- Three primary color display circuit
