Reset timing circuit when power is turned on
Source: InternetPublisher:拿铁三分糖 Keywords: power supply timing circuit trigger Updated: 2021/02/14
(1) Introduction to the circuit principle The circuit is shown in Figure 3-41. The function of the ④ pin of NE555 is to operate the circuit when connected to a high level, and to reset the circuit when connected to a low level
. The circuit is connected to the ruler at pin ④. and G have a time constant function. Therefore, after the power is turned on, the ④ pin will not rise to +ULI immediately. ,
it needs to rise to +Ud- after the delay of the wind and Cz time constants. During this period, even if pin ② inputs a trigger pulse. ③Pin output still remains low
. The island and pin are the limiting resistors of NE555, which are used to prevent excessive current in c2. The FTL level trigger pulse directly triggers
the ② pin of NE555 through Rz . VD1 is used to quickly discharge C2 when the power supply is disconnected, and the output pulse width is T=Rs.
(2) Component parameter selection The selection of components is shown in Figure 3-41, and there are no special requirements.
(3) The reset timing circuit when the power is turned on is shown in Figure 3-41.
- How to use a microcontroller to control a servo motor?
- How to choose the right level of integration to meet motor design requirements?
- How to build a simple tachometer using an infrared reflectance sensor
- Squirrel cage asynchronous motor reverse braking control circuit
- Motor self-starting circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Do-it-yourself trial production of phase failure protection device
- Simple three-phase motor phase loss protection circuit
- Home wireless burglar alarm circuit
- Vibration anti-theft alarm circuit
- Multi-channel patrol detection control circuit b
- Electric blanket, rice cooker timing circuit a
- Long time timing circuit composed of 555
- NS303 timing circuit with display function
- timing circuit
- Long-term high-precision timing circuit
- Dual 555 constitutes a 4h sequential timing circuit
- Timing circuits from minutes to hours
- Novel factory timing circuit diagram
- Simple timing circuit
