Share an interesting LED decoration project
Source: InternetPublisher:走马观花 Keywords: led ic555 Updated: 2025/01/07
LED Chakra is a decorative lighting system that depicts or mimics the appearance of a spinning wheel through an array of light-emitting LEDs that move in sequence.
The Indian subcontinent is a land of festivals and celebrations that mainly start in August and continue till the New Year. All these festivals have one basic thing in common, which is the dazzling colorful lights that flash in various patterns and sequences. Most of these lights are in the form of LED lights as LEDs are the most efficient in terms of brightness and cost.
In this article, we will discuss one such interesting LED decoration project that will mimic the spinning illuminated chakra lamps. These can be seen behind the crowns of popular God idols like Lord Ganesha, Sai Baba, and around the fingers of Lord Vishnu.
Working Theory
The working principle of this LED Chakra circuit is based on the popular IC 4017 and IC
555 chase circuit. The only difference is in the output driver stage which has been upgraded to a delayed OFF timer stage to introduce an attractive slow fade effect.
The slow fade-in and fade-out effect induces the persistence of visual effects that we usually experience in real-life rotating devices such as fans, motors, wheels, etc.
This allows the LED Chakra to achieve a real shiny spinning metal effect when placed behind the God idol.
Circuit Description
As mentioned above, the design is adapted for IC 4017, which is Johnson's 10-stage decade counter divider IC, and IC 555, a basic astable multivibrator.
IC 555 oscillates at a rate of about 50 to 100 Hz (adjustable) and provides the required clock pulses to pin #4017 of IC 14 .
IC 4017 converts the clock into momentary conduction, switching high logic on its output pin.
These shifted logic levels are fed to the array's delayed turn-off transistor stage, which keeps the sequence firing for a moment, rather than shutting off immediately.
This enables the corresponding transistor stage to keep the LED lit for a certain period of time and provide the desired spinning chakra effect, with time lag.
Parts List
All resistors are 1/4 Watt 5%
10K - 10
22K - 10
33K - 1
100K or 330K Potentiometer - 1
Capacitors
0.01uF - 1
0.1uF - 1
1uF/25V - 1
33uF/25V - 10
semiconductor
1N4148 - 10
BC547 - 10
LED - 40
Integrated Circuits 4017-1
Integrated Circuit 555-1
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Analysis of the basic principle of measuring resistance by bridge method
- The Importance and Ideal Model of Impedance Matching
- What are the classifications of filters?
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Why use PWM? What are its advantages?
- How to install the accelerometer
- FL52C4 induction electronic greeter
- Analysis of various forms of packaging structures of LED light-emitting diodes
- Circuit using NCP1216 to drive LED
- LED cycle lighting circuit controlled by 12C508A
- Driving circuit diagram of a low-power LED bulb
- LED backlight driver module design circuit
- Ordinary optocoupler isolation circuit
- LT3755 driver LED application circuit diagram
- LED lighting display detection circuit with overload protection
- Transformer overtemperature alarm circuit
- LED billboard decorative light circuit
