PLC controls motor forward and reverse circuit
Source: InternetPublisher:萌面大虾 Keywords: Motor PLC control Updated: 2021/05/08
The direction of rotation of some single-phase AC motors changes depending on their wiring. The circuit shown in Figure 4-6 shows that when a PLC is used to control
the forward and reverse rotation of this type of motor, there must be
a delay
between opening the forward control contact and closing the reverse control contact .
The H terminal of the IP series PLC can be connected to the live wire
or the center wire, but the H terminals between the two groups are insulated from each other
The forward rotation, reverse rotation and stop of the motor are controlled by two input signals xo and Xl . Figure 4-6b
shows the motor forward and reverse RLL program. Their
logical relationship is shown in Table 4-1.
If you use this method to control a three-phase asynchronous motor , you must pay great attention to the instantaneous connection of YO and Yl, otherwise the equipment will be easily damaged.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- Tutorial on making your own remote-controlled robotic arm
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- One-way rotation circuit of motor controlled by contactor
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of wire control circuit
- Light-controlled circuit design and analysis
- Simple three-phase motor phase loss protection circuit
- Water supply reminder after water outage
- Multi-channel patrol detection control circuit b
- Digital camera flash control circuit
- High-rise residential walkway lighting control circuit
- PLC chain alarm control circuit used in production process
- Haier KFR-25GW air conditioner control circuit schematic diagram
- Intelligent iron control circuit
- Micro DC motor steady speed control circuit a
- Temperature detection control circuit for vegetable greenhouses
- PLC controls motor forward and reverse operation circuit
- PLC control water pump motor wiring principle circuit diagram
