12V NiCAD Battery Charger Circuit Schematic
Source: InternetPublisher:兰博 Keywords: Battery charger battery circuit Updated: 2024/06/07
The figure below is a schematic diagram of a 12V NiCAD battery charger with a charging rate of 200mA/Hour.
Components List:
Resistors: 1KOhm, 68Ohm, 2KOhm, potentiometer 10KOhm
Diode: IN4001, 2xZenerIN752
Transistor: 2N2219, 2N2222
This NiCad battery charger circuit charges a battery at 75mA until the battery is fully charged and then reduces the current to a trickle rate. It will fully charge a dead/unpowered battery in 4 hours and the battery can be left in the charger indefinitely. To set the shutoff point, connect a 270 ohm/2 watt resistor between the charge terminals and adjust the potentiometer to 15.5V.
The input voltage of this battery charger circuit is 24VDC, you can use a universal power supply or a 24V lead-acid battery from your car.
- Dual Power Supply Circuit Analysis
- 7805 adjustable voltage regulator circuit diagram, 7805 circuit analysis
- What does power ripple mean? How big is the DDR power ripple requirement?
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Build a simple buck-boost regulator and test it on a breadboard
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- Cadmium nickel battery charger circuit three
- One of the nickel-cadmium battery charger circuits
- Ni-Cad battery charger zapper circuit
- PUT battery charger circuit
- Automatic stop charging battery charger circuit
- Universal battery charger
- Battery charger circuit diagram with discharge function
- Using LTC1148 to form a high-efficiency nickel-cadmium battery charger circuit diagram
- Nickel-cadmium battery charger circuit diagram using 5G167
- Solar battery charger circuit diagram
