A doorbell circuit with a blinking LED
Source: InternetPublisher:smallembedded Keywords: led doorbell circuit NE555 Updated: 2023/12/08
This is a doorbell circuit with flashing LED to make the circuit more attractive. IC1 (NE555) is used here as clock generator. It is actually set up as an unstable multivibrator, the frequency of which can be changed using the support of potentiometer VR1. The clock pulse received from IC1 is fed to pin 14 of IC2 (CD4017) which is a popular decimal counter circuit module.
In this doorbell circuit with blinking LED, the LED is connected in a completely different way. The LEDs flash from Q0 to Q9 in sequence. Five 100k trimmers are connected to each pair of LEDs individually.
IC3 is used as a tone generator, and a Darlington bank consisting of transistors BC547B and SL100B is then applied to boost its output, enabling the circuit to drive a speaker. The frequency of IC3 is changed by potentiometer VR2. Each 100k spinner (VR3 to VR7) is fine-tuned to allow various adjustments based on personal decisions. The 10 LED displays are set up in such a way that the first vertical column has orange LED1 to LED5 and then the second parallel column has green LED10 to LED6 as shown in the above circuit.
The circuit can be easily built on veroboard. Any good filtered 9V, 250mA DC power supply is suitable. The primary of the power transformer can be connected to the bell AC outlet factor.
- Child missing reminder
- NE555 exit reminder
- Telephone call time reminder composed of NE555 and CD4017
- Using NE555 to make a digital logic test pen
- Making a timer with NE555
- 555 transformerless DC/I)t2 positive voltage output circuit
- 555 light control and infrared sensor energy-saving lamp circuit
- 555 zero symmetrical bidirectional pulse wave generator circuit
- 555 infrared sound and light alarm circuit
- 555 automatic heater circuit for lower limit temperature reporting
- Circuit diagram of a high-brightness and energy-saving LED lamp cup
- LT3755 driver LED application circuit diagram
- LED backlight driver module design circuit
- High battery life LED circuit based on GEC8310
- Ordinary optocoupler isolation circuit
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- Five-digit LED display audio power indication circuit diagram made with FD502
- Five-digit LED level indication driver integrated circuit typical circuit
- Soil moisture detection circuit
- Basic structure of light-emitting diode (LED) display drive circuit
