Using NE555 to make a digital logic test pen
Source: InternetPublisher:张三叔 Keywords: NE555 logic test circuit Updated: 2024/08/21
This circuit uses the set and reset characteristics of the trigger terminal 2 and the threshold terminal 6 of the 555 circuit to form a test pen to detect whether the digital logic state is normal. If the probe IN input is low level "0", LED2 lights up, and when the input is high level "1", LED1 lights up. The R1, C2 and R2, C3 networks are acceleration networks. This logic pen is suitable for testing digital circuits such as TTL and CMOS. When measuring, this circuit should be grounded with the circuit under test.
- Fan frequency speed regulation circuit realized by 555 timer
- NE555 sequential timing circuit diagram
- IC555 circuit diagram based on monostable multivibrator
- 555 infrared transmitter circuit
- 555 pyroelectric infrared sensing and lighting dual control delay energy-saving lamp circuit
- 555 automatic timing controller circuit
- 555 simple electronic keyboard circuit (1)
- 555 automatic heater circuit for lower limit temperature reporting
- 555 electric bicycle pulse speed regulating device circuit
- 555LCD digital clock hourly self-timer circuit
- NE555 exponential voltage controlled oscillator circuit diagram
- multi-tone alarm
- Use NE555 to make voice-controlled music lanterns
- Use NE555 to make light-controlled automatic lights
- Use NE555 to make a single-button touch light switch
- Ultrasonic liquid level indication circuit diagram composed of NE555
- Clever use of NE555 as long timer circuit diagram
- NE555 as negative voltage generator circuit diagram
- Bipolar DC and DC voltage stabilizing converter circuit diagram composed of NE555
- Switching regulated power supply circuit diagram composed of NE555
