A simple proximity infrared detector circuit
Source: InternetPublisher:拿铁三分糖 Keywords: Proximity sensor infrared detector LM567 Updated: 2024/01/04
This is a simple circuit for proximity infrared detector, based on proximity sensor? Infrared. The applications of this circuit are the most diverse. From placing them on the front door to prevent people from parking in front of the track, to even placing them on the back and front of the car to warn other drivers if they get too close to the park.
Circuit operation is based on emitting an infrared light signal that bounces off a nearby object and is received by another component. Upon receipt, the system detects proximity to the LED output which is activated (lights up).
This integrated circuit is a tone generator/decoder and serves the needs of this design well. Both photodiodes and phototransistors are placed in a suitable way to improve the range. Available range with simple LED reflector is meters. A distance of five meters can be covered using a convex lens. It is convenient to sacrifice some range but place a UV filter that does not let the phototransistor (receiver element) shine with sunlight.
The power supply for this circuit can be anything between 5 and 9 volts.
Driving an external circuit will be enough to replace the LED with an optocoupler that is controlled by its internal transistor circuit.
- Working principle and characteristics of electromagnetic relays, selection method of rated working voltage of relays
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to make a wheeled self-balancing robot using ultrasonic sensors
- How can we make the robot move precisely on a predefined path?
- Motor control circuit for starting and running without phase loss
- Design and analysis of wire control circuit
- IGBT modules block overcurrent by controlling the gate
- Temperature control circuit design and analysis
- Precious home appliance anti-theft alarm
- Car audio system anti-theft circuit
- Egg heating control circuit
- Pyroelectric automatic door control circuit
- Simple timing control circuit
- Mobile phone camera flash control circuit
- time control circuit
- Multi-pole leakage protector circuit a
- Neon light control circuit
- Humidity detection box control circuit in greenhouse
- Micro DC motor steady speed control circuit a
- Precision timer composed of LM567 and MP1826
