In-phaser and inverter: In-phaser (tTx) and inverter (FX) are composed of operational amplifiers and peripheral components to respectively control the forward and reverse rotation of the motor
to achieve tool advance and retraction. When the tool is being processed, the speed change (ST) output is a positive signal . , added to the input end of 'IX, a trigger pulse is generated through the trigger circuit
1, triggering VS1 to conduct, and the motor rotates forward. At this time. VS2 is closed and not working. In the same way, the inverter controls the reverse rotation of the motor
- Detailed explanation of the working principle of the clapper activated optical circuit
- IoT-based weather data logger
- Design of a drone wildlife counting system using FOMO object detection algorithm
- Building a Dehumidifier for a 3D Printing Dry Box
- Building an open source dynamic light scattering device
- Share a fire sensor solution using MLX90640
- Analysis of the circuit principle of ZX5-630 welding machine
- Frequency signal tracking circuit (phase-locked loop circuit) composed of CD4046
- Using VPX-based PCIe systems for asynchronous clocking
- Laser adjustable constant current drive circuit
- Hisense KFR-25GW-06BP inverter air conditioner indoor fan motor drive circuit
- Longitudinal differential protection circuit
- Fully automatic washing machine motor drive schematic diagram
- Schematic diagram of current direction and coil rotation direction of DC brush motor
- Relationship diagram of the main components of DC brush motor
- Hall element and motor starting principle b
- Triac motor drive circuit b
- PLC controls motor bidirectional limit circuit
- PLC controls motor forward operation circuit and ladder diagram
- One SIPU STR soft starter controls two motor circuits b
