Hydraulic rotary table control circuit 01
Source: InternetPublisher:方世玉223 Keywords: Hydraulic control circuit BSP switch Updated: 2020/12/17
The control circuit of the hydraulic rotary table is shown in Figure 2-24. In the picture, the soi is pressed down when the fine disk is lifted up. S02 is pressed down when the turntable is almost in position
and raised when the turntable is in position. s secretly presses #KAl9 at the end of the turntable counter punch. It is the power head backward action relay, KA11 is the power Yu
processing completion relay, KA:t2 is the action head original five signal relay; SA; it is the rotary table automatic With the semi-automatic working state selector switch , S Al
is the power head independent adjustment pan as the selector switch
. Press the ship to cancel the work, and start the forward movement of the power head independently. - '
When the circuit is working, the rotary table needs to be in a semi-automatic working state, and the selector switch SA should be in the M position.
- How to convert digital values into analog values by connecting MCP4725 with Arduino
- How to use Tesseract for optical character recognition on Raspberry Pi
- How to connect TFT LCD to Raspberry Pi
- IoT-based pet feeder
- A novel resonance demonstration device
- Production of electric mosquito killer
- How to use RFID to create an automatic roll call attendance system
- How to Build a Low-Cost Arduino MiniCNC Plotter
- Input and output polarity reversal circuit composed of MAX660
- How to build an internet-connected traffic meter
- Analysis of rectifier circuit types and principles
- Physiotherapy ventilator circuit
- Rural vegetable greenhouse lighting circuit
- Biogas concentration detection line
- Farmland drainage automatic control circuit
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- color discrimination circuit
- Fault signal trip circuit
- Sawtooth wave generator circuit (2)
