Input and output polarity reversal circuit composed of MAX660
Source: InternetPublisher:qoistoochee128 Keywords: Inverter circuit MAX660 Updated: 2024/08/05
The input and output voltage reversal circuit of X660 is shown in the figure. The input voltage is 1.5~5.5 V, and the voltage can be outputted as -1.5~-5.5 V after voltage reversal. When the load current increases, the output voltage will drop. For example, when the load current is 100 mA and the input voltage is 5 V, the output voltage is about -4.35 V. The ripple of the output voltage is related to the load current, the oscillation frequency, the capacity of C2 and the ESR. When the oscillation frequency is 10 kHz, C2 is 150 μF, and the ESR is 0.2 Ω, the ripple voltage is about 90 mV (100 mA current); if C2 is 390 μF, the ripple voltage can be reduced to 45 mV. (a) Positive input and negative output; (b) Negative input and positive output.
- Share a board game electronic dice circuit
- Using BMP280 to make a weather station
- How to connect TFT LCD to Raspberry Pi
- How to implement semaphores and mutexes in FreeRTOS using Arduino
- Building a Dehumidifier for a 3D Printing Dry Box
- Plastic sealing machine circuit diagram
- Simple and easy-to-make electronic mosquito repellent
- Infrared detection type electronic rodent killer circuit
- Using VPX-based PCIe systems for asynchronous clocking
- Bookcase moth-proofing circuit made with 7556 dual-time base circuit
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
