Home > Audio/Video Circuits >Audio Amplifier Circuits > 18W Class B audio amplifier
Source: InternetPublisher:RCHV1r8J1 Keywords: Audio amplifier Updated: 2026/03/27
Circuit diagram:
18W Class B Audio Amplifier
Component:
P1______________50K Logarithmic potentiometer (or 47K)
                    (Dual concentric shaft dual-coupling for stereo)
P2______________20K linear potentiometer (or 22K)
P3_____________100K Linear Potentiometer
R1_____________820R 1/4W resistor
R2______________68R 1/4W resistor
R3______________1K8 1/4W resistor
R4______________10K 1/4W resistor
R5_______________1K 1/4W resistor
R6, R7__________100R 1/4W resistors
R8_____________330R 1/4W resistor
R9______________47R 1/2W resistor
C1_______________1µF 63V Polyester Capacitor
C2______________33pF 63V Polystyrene or ceramic capacitor
C3______________10nF 63V Polyester Capacitor
C4, C5____________1nF 63V Polyester Capacitor
C6_____________120nF 63V Polyester Capacitor
C7______________22nF 63V Polyester Capacitor
C8,C10_________220nF 63V Polyester Capacitor
C9______________22µF 25V electrolytic capacitor
C11, C12________220µF 25V electrolytic capacitors
IC1__________NE5534 Low-noise single operational amplifier
Q1____________BD440 60V 4A PNP transistor
Q2____________BD439 60V 4A NPN transistor
J1______________RCA Audio Input Jack
Comment:
To meet the repeated requests from the communicator, a medium-power audio amplifier with tone control included in the feedback path was finally designed.
To avoid an excessive increase in the number of parts due to the addition of tone control, based on successful...
 45W Class B amplifier
The same guiding principles were used to design a simple amplifier circuit, but the excellent NE5534 integrated circuit was used instead of discrete component operational amplifiers to drive the output "damping" transistor.
A special circuit configuration allows the NE5534 to be driven to its limits, enabling the entire amplifier to deliver relatively high power output without problems. Therefore, 18W of power can be obtained with an 8-ohm load using a +/-20V supply voltage.
Despite the added complexity of tone control, the amplifier has an input sensitivity of 130mV RMS, allowing direct connection to most different audio sources without the need for a separate preamplifier.
The total harmonic distortion data is extremely low, far below that of comparable audio amplifiers using a single integrated circuit audio amplifier.
One interesting feature of this amplifier is that it requires no setup whatsoever.
Bass and high frequency response:
Bass and Treble Frequency Response
Power supply circuit diagram:
Power Supply for the 18 Watt Class B Audio Amplifier
Power supply components:
R1______________1K8 1/4W resistor
C1,C2_________4700µF 25V electrolytic capacitors
D1_____ Diode Bridge 100 to 400V, 1.5 to 4A
D2______________LED Any type and color
SW1_____________Single-pole single-throw main power switch
T1______________230V primary, 30V center tap or 15+15V secondary.
                    Main power transformer, approximately 45 to 60 VA or 1.5 to 2 A.
PL1_____________Main power connector with cable
Comment:
The power supply section is simple. The recommended component values ​​apply to the stereo version of this design. For a mono amplifier, a lower-power mains transformer with a 30V center tap or a 15+15V secondary winding can be used, with a rated power of approximately 24 to 30 VA or 0.8-1 A.
The Q1 and Q2 power transistors should be mounted on a heatsink of at least 100x50x25mm.
+22V and -22V are the absolute maximum permissible supply voltages for the NE5534: Do not exceed these limits.
If a higher voltage is required from the power supply, consider using a regulated power supply. Please refer to [link/reference].
  Simple, efficient, and regulated power supply
Technical data:
Output power:
 18 watts RMS into 8 ohms (1kHz sine wave)
 Input sensitivity:
 130mV RMS for full output
 Frequency response @ 1W RMS and tone control at the middle position:
 -1.2dB from 50Hz to 15kHz; -3dB @ 20Hz; -2dB @ 20kHz
 Total Harmonic Distortion @ 1kHz:
  500mW
 0.005%
  1W
 0.0035%
  10W
 0.0035%
  18W
 0.008%
 Total harmonic distortion @10kHz:
  500mW
 0.007%
  1W
 0.004%
  10W
 0.01%
  18W
 0.024%
 Unconditionally stable on capacitive loads
