PLL tuning module
Source: InternetPublisher:0lW88MhX Keywords: PLL tuning module Updated: 2026/04/10
PLL Tuning Module
Phase-locked loop tuning module
The SAA1057 dual-speed phase-locked loop is designed for broadband FM transmitters.
PLL Tuning Module
Technical Specifications:
Power supply: 8-15 V regulated, 40 mA
Frequency range: 82.5-108 MHz
Step frequency: 100 kHz
RF input voltage range: 10-500 mV
RF input impedance: 135 ohms
Schematic diagram:
Pin meanings:
1 - Tuning Voltage (Output)
3 - Radio frequency signal (input) from the oscillator
2, 4 - Earth
Tl1 - Reset
Parts list:
Capacitor:
C1, C12 - 2.2 nF (ceramic)
C2, C9 - 10 nF (ceramic)
C3 - 47 uF (electrolysis)
C4 - 10 uF (tantalum)
C5 - 0.47 uF (electrolysis)
C6, C11 - 100 nF (ceramic)
C7 - 1 nF (Ceramic)
C8 - 220 uF (electrolysis)
C10 - 22 pF (ceramic)
Resistor:
R1 - 1k
R2 - 4.7k
R3, R4, R5, R7 - 10k
R6 - 1k (optional)
R8 - 47k (optional, see below)
other:
IC1 - SAA1057
IC2 - PIC16F84 (programmed) + socket
IC3 - 78L05
X1 - 4 MHz crystal
D1 - LED diode (optional)
Tl1 - Button (optional)
Jumper or DIP switch
IC2's software:
pll16f84.asm, pll16f84.hex. Oscillator type: RC, Watchdog: On.
Jumper/DIP switch settings: See pllfreq.txt or download the user-friendly program!
illustrate
Tl1 Button Reset Unit. Press it after setting the frequency. The unit provides a reset when the power is on, so you do not need to use this button.
LED D1 indicates that the tuning cycle is complete (one second after reset). It and resistor R6 are not required.
Resistor R8 provides a minimum voltage of approximately 2V to the PLL output. Use this resistor if the transmitter oscillator does not function when the tuning voltage is below this value (primarily after power-on). Place the resistor across R3.
Precautions:
The PLL output should not be directly loaded with a large capacitor (more than approximately 0.3 uF). The PLL loop may be unstable. This applies to some unknown transmitters.
PCB layout
PR = Line Bridge
PLL Tuning Module
PLL Tuning Module
