Simple and efficient LED constant current drive circuit diagram
Source: InternetPublisher:elleny Keywords: Drive circuit diagram LED constant current drive circuit output current HSPICE Updated: 2020/10/24
Based on the light-emitting characteristics of LED , this article proposes a wide voltage input, high efficiency, and high dimming ratio LED constant current drive circuit. This circuit has the advantages of simple structure, fast dynamic response, and no need for compensation circuits. Through external pins, LED switching, analog dimming and PWM dimming can be easily performed. The LED constant current drive circuit is based on CSMC's 1μm 40VCDMOS process and uses HSPICE for simulation verification. The results show that within the input voltage range of 8~30V, the maximum output current of the circuit can reach 1.2A, the output current accuracy can be controlled within 5.5%, and the power efficiency can be As high as 97%. The details are shown in the figure below:
![Simple and efficient LED constant current<strong>Drive circuit diagram</strong>](http://www.eeworld.com.cn/circuit/upload/a81ab736f2d178b2b6ad57e4161f5093/2c31762ba51c9179f5c77bc0ca31f6a6.jpg)
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Simple and practical LED lamp driving circuit
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- A novel and practical DC low voltage stabilized power supply
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- Adjustable voltage regulated power supply circuit
- A low-cost, high-reliability battery charger for electric vehicles
- Power circuit of STR5412
- Portable device charging power circuit design
- Laser power circuit
- EPSON PHOTO 830U printer power circuit
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Warm current power supply circuit b
- Low voltage adjustable reference power circuit
- Common power circuits and applications 01
- 25Hz ring current power supply circuit
- CTX-C2 dual-band high-resolution color display power circuit
