40V 2A power supply based on LM317 and TIP42
Source: InternetPublisher:YDvUBGMcP Keywords: LM317 power supply Updated: 2026/04/14
40V 2A LM317 and TIP42 power supply
A very good and powerful regulated power supply section was achieved by simply adding a PNP power transistor to the excellent LM317T adjustable regulator chip. In this way, the circuit can easily provide far more power than is required to drive two Mini-MosFet amplifiers to full output (at least 2 Amps @ 40 Volts at a 4-ohm load).
R1_______________3R9 1 or 2 watt resistor
R2______________22R 1/4 watt resistor
R3_______________6K8 1/4 Watt Resistor
R4_____________220R 1/4 Watt Resistor
R5_______________4K7 1/2 Watt Resistor
C1____________3300µF 50V electrolytic capacitor (or 4700µF 50V)
C2, C5__________100nF 63V Polyester capacitors
C3______________10µF 63V electrolytic capacitor
C4_____________220µF 50V electrolytic capacitor
D1_____Bridge rectifier 100V 4A
D2___________1N4002 200V 1A Diode
D3______________LED Any type and color
IC1___________LM317T Three-terminal adjustable voltage regulator
Q1____________TIP42A 60V 6A PNP transistor
SW2_____________Single-pole single-throw power switch
T1_____________230V Primary, 35-36V (center tap) Secondary, 50-75VA Power Transformer (see notes)
PL1____________ Male power plug with wire
- 40V 2A power supply based on LM317 and TIP42
- Precision low voltage power supply
- 3.3V and 5V power supply
- Automatic battery charger
- Simple ±22V voltage regulator
- Solar cell charger based on LM317
- USB Lithium Polymer Battery Charger
- How to Determine Bandwidth from Transient Response Measurements
- A flyback converter solution where two outputs are better than one
- Recommendations for 5G small base station power supply design
- For Schottky rectification, what are the advantages of synchronous rectification?
- Do you know how to select the IC chip of the power adapter?
- Do you know the possible reasons why the power adapter cannot be used universally?
- Causes of inductor whistling in DC/DC circuits and related solutions
- How to choose a power supply?
- Power phase failure display circuit
- Output 85 to 145V adjustable regulated power supply circuit
- Basic application circuit diagram of LM317
- High stability power supply circuit diagram using LM317
京公网安备 11010802033920号
