50MHz frequency meter
Source: InternetPublisher:GiWSozVa Keywords: Frequency meter Updated: 2026/04/03
This new 50MHz frequency meter features auto-range and displays frequencies in Hz, kHz, or MHz. This makes the device easy to read as it automatically selects the correct range for any frequency between 0.1Hz and 50MHz and correctly inserts the decimal point in each reading. Note that while we specify a maximum frequency of 50MHz for this frequency meter, most units are capable of measuring frequencies slightly higher. In fact, our prototype was able to measure frequencies up to 64MHz and above.
Frequency counters are used in almost every area of electronics and are invaluable in repair and diagnostics. Beyond that, they are ideal for checking the operation of oscillators, counters, and signal generators. They can also be used to repair RF equipment or simply to provide accurate frequency readings for function generators. This design is also easy to build because it uses a programmable PIC microcontroller to handle all the intelligent functions. In addition, there is an LCD reader, several low-cost ICs, two transistors, a three-terminal regulator, and some miscellaneous components to complete the design.
Key features
* Compact size (130 x 67 x 44mm)
* 8-digit display (LCD)
* Automatic Hz, kHz, or MHz indication unit
Two resolution modes
* 0.1Hz resolution, up to 150Hz
* 1Hz resolution, up to 16MHz
* 10Hz resolution, higher than 16MHz
* Powered by battery or DC power adapter
- Towel machine fault detection circuit
- Computer power detection circuit
- Three-phase AC phase sequence detection circuit
- Detect the major point waveforms of the circuit
- α-ray application detection circuit
- Light detection circuit
- Cordless telephone ring current detection circuit
- Hot spot sensor infrared detection circuit
- Human body detection circuit within mechanical action range
- Human body detection circuit for infrared sensor
京公网安备 11010802033920号
