AVR LCD Thermometer—LM35
Source: InternetPublisher:9xNPSFu Keywords: AVR LCD thermometer Updated: 2026/03/27
AVR LCD Thermometer LM35
The National Semiconductor LM35 used in this project is a precision Celsius temperature sensor with an analog output voltage. Its range is -55ºC to +150ºC with an accuracy of ±0.5ºC. The output voltage is 10mV/ºC. The output voltage is converted by an ATmega8 AD converter. The temperature is displayed on an LCD module. In this example, the thermometer has a range of 0ºC to 40ºC and a resolution of 0.5ºC. If you require Fahrenheit readings, you can use the LM34.
- AVR PC Stepper Motor Driver
- Parallel port-based PIC online programmer
- Relay timer based on PIC16F628
- How to make a simple programmer for STC12 series microcontroller
- Isolated data acquisition system circuit composed of AD7714 and microprocessor
- Interface circuit between PDIUSBD12 chip and 51 single-chip microcomputer
- How to display numbers on 7 segment display using 8051 microcontroller?
- What is the difference between a microcontroller and a microprocessor?
- Application circuit of CSJ-R05B and single chip microcomputer
- Computer USB port to mobile phone interface conversion circuit
- An LCD and controller interface circuit diagram
- Ultra-low power consumption LCD liquid crystal display circuit module design diagram
- LCD boost circuit for MP3 player
- LCD backlight boost circuit
- Lixin LCD switching power supply partial circuit diagram
- MAX16834 driver LED circuit
- LCD power bias circuit diagram
- 4-digit LCD static display circuit
- MPX5100 LCD pressure gauge circuit
- LCD scanning interface conversion VGA interface circuit diagram
京公网安备 11010802033920号
