Light-controlled/dark-controlled relay switch
Source: InternetPublisher:SPlj9T1 Keywords: relay switch Updated: 2025/11/21
A simple light/dark activated relay switch circuit suitable for many applications, such as automatically switching the lights in a shop window or room based on ambient light levels. The circuit uses a photoresistor (LDR) and includes a light/dark option. The term "light/dark" is used because there is a PCB-mounted switch on the board. In one switch position, the transition from light to dark activates the relay. In the other position, a transition from dark to light is required. Therefore, you can use the light reduction on the detector to open a normally open circuit or close a normally closed circuit. The relay is on when the LDR is not covered and off when the LDR is covered. Adjust VR1 to set the light sensitivity. The LED will light up simultaneously with the relay.
Power supply: 12 to 15V DC
Relay contact rating: 5A / 240V AC
- Timed chicken coop door opener
- Device control using dual-tone multi-frequency (DTMF) signals
- Drain pump controller
- wiper speed control circuit
- Speed limit alarm
- Solar panel controller
- Wireless security alarm
- Simple doorbell composed of CD4060
- Tips for Current Regulation When Microstepping a Stepper Motor
- A switch controls the start and stop circuit diagram
- Flashing wall light control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Simple timing control circuit
- Electromagnet control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Chandelier control circuit
- Photoelectric detection output control circuit
- Temperature detection control circuit of electric hot water bottle
- Button type electronic volume control circuit
- Power supply circuit with multiple outputs (MAX1902)
京公网安备 11010802033920号
