Flashing wall light control circuit
Source: InternetPublisher:张三叔 Keywords: Control circuit NAND gate BSP Updated: 2020/06/06
Shown is a simple flashing wall light control circuit . VD1, VD2, R3 and C2 in the circuit form a resistor step-down half-wave rectifier and
voltage stabilizing circuit, which can obtain 12 V DC voltage for circuit operation. The NAND gate and 2 form a multivibrator. By adjusting the RPI, its oscillation
frequency can be changed, so that the wall lamp lighting can flicker and glow to achieve a satisfactory effect.
When the circuit starts to oscillate, the output terminals of NAND gates 1 and 2 will alternately appear high and low. When the NAND gate l outputs a high level,
the trigger thyristor VS2 is turned on, and when H2 is lit, the NAND gate 2 outputs a low level , the thyristor VS1 is turned off, and the lamp H goes out.
- Model rocket launch controller circuit
- Car ice warning circuit sharing
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Introduction to the internal structure of the Delta winding motor
- A small improvement on the ordinary refrigerator motor starting circuit
- Motor self-starting circuit
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and production of no-load automatic power-off device for household power supply
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- stuttering correction circuit
- Peanut and melon seeds roasting machine circuit
- Rural fish farming control circuit
- Particle clogging alarm circuit of wheat seeder
- Agricultural spraying and insecticide control circuit
- Varactor Diode Frequency Modulator
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
