Adjustable crossover point balanced subwoofer circuit
Source: InternetPublisher:桂花蒸 Keywords: BSP Updated: 2020/10/27
This circuit can mirror and improve the low-frequency attenuation of the subwoofer, thereby evenly broadening the low-frequency response to
about 20Hz.
Figure 9-75 is the schematic diagram of this circuit.
This circuit consists of input level selection, equalization, frequency division, and promotion. Level indicator and power supply are composed of five parts.
This circuit is equipped with two input terminals AB. The former is used for high-level input and can be connected to the main channel speaker output; the latter
is used for low-level input and can be connected to a preamplifier. line output. The cutoff frequency of the crossover circuit is adjustable in 4 steps, limiting the speaker's
playback of frequencies above 70Hz.
ICla is an adder that mixes the stereo left and right channel signals through Rl, R or R3, R and
amplifies them by ICla. The amplification amount can be adjusted by RPi connected in the negative feedback loop, so RPi is the subwoofer volume control.
IC2d and IC2,c form a low-frequency boosting circuit . IC2a and its peripheral components form a second-order low-pass filter. Its output
is sent to the inverting auxiliary input terminal of IC.2c through island and island, while its non-inverting input terminal passes through C4, Rn is augmented with the full frequency signal from the ICla output
, so that IIC2c outputs a low frequency boosted signal. C3 and C4 respectively limit the signal bandwidth entering IC2c, coupled with
the additional correction effect of IClb input terminal Rzs~‰ and island, the low-end frequency response is finally broadened.
IC2b and its input part RC components form a third-order low-pass Butterfly Si filter, its cutoff frequency can be selected by Sl
, which are 40H, 50Hz, 60Hz, and 70Hz from top to bottom. Changing the corresponding resistance value can easily set the cutoff frequency
to other required values.
- Tutorial on making a MIDI arpeggio synthesizer
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- The easy production of several top-quality tube preamplifiers
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Installing a tube preamplifier in the power amplifier
- Stereo tube power amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- LM4902 differential input audio amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- LM4906 Audio Power Amplifier Circuit
- Smoking Cessation Circuit
- soil content measurement circuit
- Egg warming circuit
- Straw returning to field crusher circuit
- Soil water shortage prompt circuit
- Domestic KD8041 integrated phase locked loop
- Proportional frequency discriminator circuit
- Second-order active band-stop filter circuit
- Three primary color display circuit
- Motorcycle flash light circuit
