YSS247 application circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: Application circuit BSP switch Updated: 2021/01/04
Compared with similar products, YSS247 has the following characteristics: fewer peripheral components. Different from SRS5250S,
YSS247 only needs one potentiometer to adjust the surround effect. Tone control and surround effects can be switched on or off via switches
. The stereo positioning of the YSS247 application circuit is accurate, the three-dimensional space effect is outstanding, and the sense of space in the horizontal direction is strong. In particular
, the center channel is accurately positioned and does not need to be adjusted. The tone control range of YSS247 is: bass 100Hz±10dB,
treble 10kH2;±10dB, signal-to-noise ratio of 95, and distortion of 0.0025%. It can be seen that its performance is still good. .
When making this circuit, pay attention to selecting high-quality components. Pay special attention to the quality of the double potentiometer, otherwise
the poor symmetry of the double potentiometer will affect the tone adjustment and two-channel surround effect. Next, we will introduce an application circuit
of YSS247 . The circuit diagram is shown in Figure 9-52.
This circuit can carefully adjust the surround effect through the switch. You can also use the switch to adjust the center frequency of the tone control
, which can achieve better results and the simulated three-dimensional surround sound field is more realistic and natural.
- TDA2009A power amplifier circuit
- Make a pocket amplifier with 8550 and 8050
- Telephone volume amplifier circuit
- The fun of making ISD1820 voice recording box
- A very simple amplifier
- Typical applications of optocouplers in audio amplifier circuits
- Dual power supply audio power amplifier circuit using LM1875
- 1OW audio power amplifier circuit using UPC1238
- 2W×2 power amplifier circuit using LM1877
- Multimedia Hi-Fi amplifier circuit
- Ultrasonic blind pathfinder circuit
- Electronic anti-asthma circuit
- Rural vegetable greenhouse lighting circuit
- Greenhouse temperature control circuit
- Farmland irrigation automatic control circuit b
- DC ammeter
- Mixer built with analog multipliers
- Crabo oscillator circuit
- Digital stopwatch display circuit
- Home appliance repair signal generator circuit
