M69032P application circuit
Source: InternetPublisher:拳制龙 Keywords: Application circuit BSP channel delay circuit Updated: 2021/08/19
The typical application circuit of M69032P is shown in Figure 9-33. The optimal input level of this device is 300rnV, and the maximum is
500mV. The left and right channel signals are input from pin 1522, the decoded main channel signal is output from pins 32 and 33, and the
center and surround signals are output from pin 3829. The subwoofer signal can be obtained by filtering the L+R signal output from pin 34. The filter
can be active or passive. This circuit uses a simple first-order passive RC filter, o is generally 100 ~ 150Hz. The
external digital delay circuit uses Yamaha YSS-288, and similar product BA5096 can be directly replaced.
You can also choose digital delay circuits
with good performance such as M50194, M50197, M65830 . The delay
time is controlled by the external resistor R31 at pin 6 of YSS-288. Different from the general karaoke delay processing, this delay
circuit does not have a feedback circuit between the input and output terminals (that is, it only has one delay). This is to ensure that
the accuracy of the original surround sound field is not affected.
- Echo Dot speaker intelligent control system solution
- Practical and high-performance preamplifier circuit
- Electronic toy dog
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- The production of 6P14 small tube amplifier
- Amplifier circuit made by parallel connection of FU-50
- LM4901 audio power amplifier circuit (MSOP package)
- LMl876 is used to assist the audio power amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- Application of BTL power amplifier circuit composed of LM3886
- strain sensor
- Biogas concentration detection line
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- Inductive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Guest arrival signal recognition circuit
- Fault signal trip circuit
- Sawtooth wave generator circuit (1)
