LM4901 audio power amplifier circuit (MSOP package)
Source: InternetPublisher:萌面大虾 Keywords: Audio Power Amplifier Updated: 2024/09/12
As shown in the figure, this is the LM4901 audio power amplifier circuit (MSOP package). After the audio signal is input, it is coupled to the inverting input terminal (pin 5) of the amplifier through Ci and Ri, while the non-inverting input terminal (pin 4) of the amplifier is connected to ground through CB. After power amplification, it is added to the speaker from Vo1 (pin 6) and Vo2 (pin 10) in the form of bridge output. There are two amplifiers inside the LM4901. The gain of the first amplifier is determined by the ratio of the external resistors RF and R, and the gain of the second amplifier is fixed to 1 by two internal 20kΩ resistors. When the LM4901 outputs in the form of bridge differential, the gain of the power amplifier circuit Av=-RF/Ri. The maximum power consumption of the LM4901 bridge differential output form is PD(MAX)=4VCC2/2π2RL, which is usually 4 times that of the single-ended output form. The SD Mode pin (pin 3) is used to select the shutdown level. If this pin is grounded, the micro-power is shut down when the Shutdown pin (pin 1) is at a low level, and the amplifier works at full power when pin 1 is at a high level; if this pin is connected to VDD, the amplifier works at full power when pin 1 is at a low level, and the micro-power is shut down when pin 1 is at a high level.
- How to adjust the bass and treble of CXA1005
- Two unique tube preamplifiers
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Using Shuguang 350C tube to make tube amplifier
- Stereo tube power amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Class AB2 Amplifier-McIntosh MC80
- LM4903/4905 high gain audio amplifier circuit
- Bridge output audio power amplifier circuit composed of LM1876
- Differential input audio amplifier circuit composed of LM4904
- Audio power amplifier circuit using MAX9789A and MAX9713 chips
- Auxiliary audio power amplifier circuit design based on LM4730
- 8W audio power amplifier circuit
- Two-channel high-fidelity power amplifier integrated circuit
- Audio power amplifier circuit using TDA8563Q chip
- Mono audio power amplifier circuit
- BTL audio power amplifier integrated circuit
- OTL audio power amplifier circuit
- 9W audio power amplifier (μPC2002) circuit diagram
- LM378 two-channel audio power amplifier circuit with adjustment circuit
