Typical applications of three-terminal integrated voltage regulators (a)
Source: InternetPublisher:睡不醒的小壮 Keywords: Three-terminal integration integrated voltage regulator BSP application circuit Updated: 2020/07/05
A typical application of a three-terminal integrated voltage regulator is shown in Figure 7-15. The figure (a) shows the application of the 78 series of integrated positive voltage stabilizing circuits, and the figure (b) shows the application circuit
of the 79 series of integrated negative voltage stabilizing circuits . As can be seen from the figure, its application circuit is very simple.
The rectified DC voltage is input into the integrated voltage regulator , and a stable DC voltage can be obtained at the output end.
The input capacitor G is used to improve the ripple of the power supply voltage. When the filter capacitor is far away from the voltage regulator, t must be connected to ci and
as close as possible to the pin of the voltage regulator. The output capacitor can improve the transient response characteristics, reduce the output impedance at high values, and
can be omitted when oscillation does not occur.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- 220V Remote Load Monitor
- The constant current source composed of two transistors can drive high power
- Principles and precautions of active discharge circuit
- Current/voltage conversion circuit using current converter
- Miniature polarity reversal power supply using MAX1721
- Adjustable regulated power supply with current limiting protection
- Design of electric vehicle charger
- Mc34063 MP3 Switching Charger
- MAX1811 Lithium Battery Charger Production
- Self-defense anti-riot circuit
- Electric massager circuit
- Smoking Cessation Circuit
- Egg warming circuit
- Diode Balanced Mixer Circuit
- Varactor Diode Frequency Modulator
- Integrated synchronous detector composed of analog multiplier MC1596
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Color display circuit
