Third order active filter
Source: InternetPublisher:走马观花 Keywords: Active filters BSP crossovers Updated: 2021/10/13
Passive crossovers have simple circuits, are more economical, and have better performance. They are currently
the crossover network used by most civilian speakers. However, the power loss of the Yuanyuan crossover is large, the levels of each frequency band cannot be
controlled independently, and the damping of the low-frequency speaker is affected by the inductor coil. What's more serious is that changes in speaker impedance
affect various characteristics of the crossover. These shortcomings of passive crossover limit its application in some highly demanding situations.
Electronic frequency division divides the sound signal into several frequency bands, and then sends the signals of different frequency bands to the corresponding
power amplifiers to drive the speakers of the corresponding frequency bands. It can be seen that the cost of electronic frequency division is high and the system is complex, requiring the same number of frequency divisions. Multiple
power amplifiers, but electronic crossover also has many advantages. It has performance that is difficult or even impossible to achieve with passive crossover.
Electronic frequency division has the following advantages compared with passive frequency division:
(1) Electronic frequency division reduces losses and reduces intermodulation distortion between each frequency band. The level of each frequency band can be adjusted independently
, making it easy to match various speakers.
(2) Electronic crossover is a speaker directly driven by a power amplifier, which has good damping and reduces distortion. This is more beneficial for low frequency band
playback.
(3) The frequency dividing characteristics of electronic components are not affected by changes in speaker impedance, and the sound quality is significantly improved compared to passive frequency dividing.
The electronic frequency divider is a probe filter, generally including Butterworth filter and Bessel filter. Among them, the Bessel filter
has good transient characteristics and ideal loudness characteristic curve.
Figure 6-27 is the circuit schematic diagram and calculation formula of second-order, third-order, and fourth-order Butterworth and Bessel filters.
In the same filter, the resistor R in the low-pass filter should take the same value. , for example, R should all be 4,7~
10k,fl, and the value of the capacitor C in the high-pass filter should also be equal. For example, C can be 4700pF~O.01p:F. In the calculation formula
, the unit of R is n and the unit of C is F.
Bandpass filters can be obtained by combining highpass and lowpass.
With the emergence of high-performance and high-power integrated power amplifier circuits, it is no longer difficult to produce electronic frequency-division power amplifiers, and the price is not very
high. When we make electronic frequency dividers, we must use high-quality components, and the values of resistors and capacitors must be accurate to ensure
the performance of the frequency divider and reduce system distortion and noise.
For the convenience of use, we can select a few more crossover points and switch them with switches to adapt to
speakers with different performances. For the selection of the crossover point and attenuation slope of the
electronic crossover, please refer to the passive crossover .
- 6P3P parallel 20W power amplifier experiment
- 75W audio power amplifier made with TMOS150
- Make a pocket amplifier with 8550 and 8050
- FU-7 Tube Amplifier Homemade
- Telephone volume amplifier circuit
- LM4766 Dual 40W+40W Power Amplifier
- The fun of making ISD1820 voice recording box
- Homemade multi-sound effects sound system
- Using 6P15 to create an ultra-linear push-pull amplifier
- Differential input audio amplifier circuit composed of LM4904
- Motor forward and reverse control wiring diagram (2)
- Fish farming thermostatic control circuit
- Rural fish farming control circuit
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- Double detuned loop frequency discriminator circuit
- Schiller oscillator circuit
- Wireless microphone circuit
- Motorcycle flash light circuit
- Sine wave signal generator circuit
