Internal circuit principle of M50194
Source: InternetPublisher:已注销 Keywords: Circuit Principle BSP Updated: 2020/05/28
The A/D and D/A modulation and demodulation of M501.94AP also adopt adaptive incremental modulation technology. Different from the single delay circuit
, it has 5 D/A demodulators and can output 5 signals with different delay times , so it is called "multi-tap". It
has a built-in 20k static memory (SRAM), a maximum sampling frequency of 500kHz, a distortion of 0.30%, an output noise of
-90dB, and a frequency response of 10kH. Figure 5. ∞ is its internal circuit principle .
M50194 has two suffix models: M50194P and M50194AP. The former has a shorter delay time in echo mode than
the latter. This needs to be paid attention to when using. oM50194AP can work in three modes: reverb, echo and surround. The
working mode It can be controlled by the level of pins 10 and 1 1 , see Table 5-16 0. In surround sound and echo mode, there are 6 delay times
to choose from; in reverberation mode, there are two combination methods, each outputting 5 delays. Different time signals . When the delay time is
different, the sampling frequency is also different. The delay time is controlled by the level of pins 12 to 14, and the corresponding delay time is
shown in Table 5-17. The delay time and function can also be controlled by a microcomputer. In this case, pin 8 needs to be set to high level .
- 6P3P parallel 20W power amplifier experiment
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- LM4766 Dual 40W+40W Power Amplifier
- The fun of making ISD1820 voice recording box
- Homemade multi-sound effects sound system
- DIY a stylish Bluetooth speaker
- Class A power amplifier circuit with an output power of 18W
- Tube single-ended class A 300B power amplifier circuit
- electromagnetic field sensor
- Ultrasonic blind pathfinder circuit
- Electric massager circuit
- Smoking Cessation Circuit
- Crop anti-frost circuit
- Agricultural spraying and insecticide control circuit
- Egg heating control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- AC voltmeter
- Capacitive feedback oscillator circuit
