M50197 application circuit
Source: InternetPublisher:方世玉223 Keywords: Application circuit BSP amplifier Updated: 2020/12/30
The typical application circuit of M50197 is shown in Figure 5-29. The audio signal sent from the microphone amplifier
or
the surround sound signal sent from the S channel is input to the IC from pin 39, and the signal after delay processing is output from pin 35, and
is appropriately adjusted by the reverberation level adjustment potentiometer RP]
Then the output from the OUT terminal is sent to the mixing amplifier to be mixed with the main signal.
When the delay selection terminal 11 pin is high level, the circuit works in the reverberation or echo state. At this time, the feedback signal output terminal
has a signal output t and is fed back to the input terminal through RP2 to obtain a long delay reverberation or echo effect. .
It can be seen from the delay time programming status in Table 5-14 that through the control of pins 12 ~ 14, 8 types of delay times can be selected. When pin 11 is
low level , the delay effect required for the circuit to work in surround sound can be seen in Table 5-14. At this time, there are 8 delay times to
choose from.
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Simple and practical small amplifier
- 75W audio power amplifier made with TMOS150
- DIY 50W Gallstone Amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Minimum output noise/reduced output power circuit using LM4910
- Typical application circuit of LM4903/4905 audio power amplifier
- Volume synchronization circuit constructed with discrete components
- LM4901 audio power amplifier circuit (MSOP package)
- strain sensor
- Self-defense anti-riot circuit
- Egg heating control circuit
- Diode square rate detection circuit
- collector amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- OTL low frequency power amplifier circuit
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Power phase sequence display circuit
