Dynamic noise reduction circuit for left and right channel separation
Source: InternetPublisher:spectrum Keywords: sound channel noise reduction Updated: 2021/03/03
The sound sources of today's audio equipment mainly come from three categories: original tapes, electromagnetic record players, and ∞ record players.
The content included in the sound sources can also be summarized into three categories: light music, pop music, and symphony. No matter what kind of music it is, the position of the band and musicians
in the entire sound field has certain standards. In the production process of traditional two-channel stereo sound sources,
it often happens that the high range of a certain section of the music is on the left. The distribution of the right channel and the right channel is uneven. Only through the artistic processing of the recording engineer can
the listener have a strong sense of presence and accurate sound and image positioning. For LM1894, since its left and right main channels are controlled
by the same sub-channel , when the high-pitched ranges of the left and right channels are uneven, that is, when a strong high-frequency
signal appears in a certain channel, it This will trigger two channels of widening at the same time. In this way, the channel with high audio signal input will be unobstructed, and
the "noise flow" of the other channel without high audio signal will also pass smoothly, resulting in a serious "dereliction" of the noise reduction function.
From the above analysis, it can be seen that two problems must be solved. The best way for channels to be triggered simultaneously is to separate the control channels. According to
the characteristics of LM1894 that does not have strict requirements on the input signal level, it is also considered that if the left and right channels are used in series,
the noise reduction amount of the noise reduction circuit can also be improved. Therefore, an LM1894 is used for the left and right channels respectively, and the two internal main signal channels are connected in series to form two noise reduction circuits controlled
by their respective control channels . This not only solves
the mutual influence of the two channels, but also increases the amount of noise reduction , killing two birds with one stone. The circuit is as shown in the figure
- Practical and high-performance preamplifier circuit
- Installing a tube preamplifier in the power amplifier
- Using 6P15 to create an ultra-linear push-pull amplifier
- 6AS7 tube amplifier
- 6BX7 10W bile duct amplifier
- Typical application circuit of LM4903/4905 audio power amplifier
- 1OW audio power amplifier circuit using UPC1238
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- Improved Marantz 7-tube preamplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- Protection circuit using uPC1237 chip
- 5.1 channel surround sound DA converter circuit
- Connection of equalizer and related circuits
- M62460 application circuit
- Application circuit of uPC1891
- Application examples of LM381f
- Application example b of LM381
- Application examples of LM381a
- Bookshelf active speaker 01
- Nx75W integrated power amplifier components
