5.1 channel surround sound DA converter circuit
Source: InternetPublisher:3228 Keywords: channel converter surround sound Updated: 2021/07/24
Shown is a 5.1- channel surround sound D/A converter circuit used in small digital products . The circuit uses the chip
model PCM1606 (D/A converter ). Its function is to convert the audio decoder (or digital signal The digital audio signal sent from the processing circuit
is converted into a multi-channel (5.1- channel ) analog audio signal.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Causes and solutions for noise in digital Class D amplifiers
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Diode-based clipping circuit
- What is the difference between high-side and low-side resistive current sensing
- Do you know about the 10kW PowerTablet™ AC-DC converter?
- Multi-standard dual-carrier stereo decoder (TDA9873H)
- Application circuit of LM1035 and 36
- 8-bit cheap DA conversion circuit without DA converter IC
- Power connector with noise canceling function
- Four-channel analog multiplexer circuit
- Four-channel differential multiplexer circuit
- Temperature compensated DA converter
- Simple DA converter
- Flyback converter circuit diagram
