M5227 application circuit
Source: InternetPublisher:常思一二 Keywords: Application circuit frequency band BSP Updated: 2020/11/21
It is the application circuit of M5227P . For the graphic equalizer, its control curve is always
represented by the logarithmic frequency axis, and the control curves are required to be the same and the intervals
are equal to ensure that each frequency band is at the maximum boost or
attenuation of the total frequency. The sound curve is relatively uniform. In order to meet
the graphic requirements for the amount rate axis, the center frequency of each control section must
also be selected according to the octave range. At the same time, in order to ensure that the mutual influence between adjacent
control frequency bands is minimal, each frequency band takes
a larger Q value and keeps the same 0
value for each frequency band. This circuit is a five-segment equalizer. The center
frequency of each control segment is selected according to 3 times the range, namely: 108Hz,
343 H, 1.08kHz, 3.43kHz, 10.8kHz,
and the value is 1-5--1.8.
In the circuit, the resistance values of RGl and RZ determine the maximum boost and attenuation of each frequency band. The larger the resistance, the
greater the boost and attenuation of each frequency band. This circuit uses ±12dB boost and attenuation. According to the technical parameters provided by the manufacturer , RGl and Rca are both selected as 2.7kflo. Since the values are small, in order to improve the input impedance of the circuit, a first-
level voltage follower is
added to the input end . Comprehensive frequency response curve controlled by
each frequency band
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Installation of electron tube differential amplifier circuit
- Typical applications of optocouplers in audio amplifier circuits
- Dual power supply audio power amplifier circuit using LM1875
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- LMl876 is used to assist the audio power amplifier circuit
- 2W×2 power amplifier circuit using LM1877
- Single power supply audio power amplifier circuit composed of LM3875
- Analysis of rectifier circuit types and principles
- stuttering correction circuit
- Inpatient pager circuit
- Fish farming thermostatic control circuit
- AC voltmeter
- Schiller oscillator circuit
- OTL low frequency power amplifier circuit
- Color display circuit
- Various signal generator circuits
- Small current generator circuit
