Single power supply audio power amplifier circuit composed of LM3875
Source: InternetPublisher:aytwartoofyoroo Keywords: Audio Power Amplifier Updated: 2024/09/12
As shown in the figure, this is the single-power-supply audio power amplifier circuit of LM3875. The basic working principle of LM3875 single-power supply is the same as that of dual-power supply, except that: when single-power supply is used, two 100kΩ resistors are used to divide the voltage to get 0.5V as the bias voltage, which is added to the 7th pin of the LM3875 input terminal through a 75kΩ resistor, so that the output voltage varies up and down with 0.5V as the reference, so that the maximum dynamic range can be obtained. *Components are optional components according to actual conditions, mainly used to suppress the high-frequency self-oscillation of the amplifier; if there is no high-frequency self-oscillation and the amplifier works stably, it is not necessary.
- FU-7 Tube Amplifier Homemade
- Telephone volume amplifier circuit
- The fun of making ISD1820 voice recording box
- A very simple amplifier
- Volume synchronization circuit constructed with discrete components
- Auxiliary audio power amplifier circuit using LM4732
- LM4901 audio power amplifier circuit (MSOP package)
- Multimedia Hi-Fi amplifier circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- Typical laptop audio power amplifier integrated circuit
- Auxiliary audio power amplifier circuit design based on LM4730
- Two-channel high-fidelity power amplifier integrated circuit
- Two-channel audio power amplifier integrated circuit
- Integrated circuit audio power amplifier circuit
- Audio power amplifier circuit using TA8216A chip
- Two-channel audio power amplifier circuit
- Mono audio power amplifier circuit
- 20W (10W×2) audio power amplifier circuit using TDA2005S
- LM388 audio power amplifier circuit
