Equalizer circuit composed of integrated operational amplifier TL084 (b)
Source: InternetPublisher:李商隐身 Keywords: Integrated op amp Updated: 2021/11/14
It is a ten-band equalizer circuit composed of TL084. Its principle and structure are basically the same as Figure 4-35 (a).
It consists of 10 operational amplifiers and 10 simulated inductors, which respectively resonate at ten center frequencies: 32Hz. 64 ratio, 125№,
250Hz., 500 ratio, lkH2: 2kHz, 4kHz, 8kHz.16kHz. Island I is their common amplifier. This circuit
is also equipped with a multi-function input preamplifier. Different audio source signals are input through the selector switch SAL.
The RIAA phono balanced input amplifier is composed of 1458 and so on. . The transistor VTi is used as the microphone input amplifier, and the volume potentiometer
RPz controls the input to the main amplifier. The Iclo line, phono player, ∞ and radio are controlled
by the volume
potentiometer RPi with equal loudness control . The circuit is also equipped with a pass-through switch SA3. For input signals that do not require equalization, SA3 can be moved
to the pass-through position and output directly.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Homemade high quality preamplifier tone circuit
- A high-quality tube amplifier with 6P3P design
- 75W audio power amplifier made with TMOS150
- Making a Simple Tube FM Radio
- Installing a tube preamplifier in the power amplifier
- DIY a stylish Bluetooth speaker
- Using 6P15 to create an ultra-linear push-pull amplifier
- Audio power amplifier circuit composed of LM4835/4838
- Class A power amplifier circuit with an output power of 18W
- Adjustment and testing of RC bridge oscillation circuit
- Linear constant current source composed of integrated operational amplifier
- Equalizer circuit composed of integrated operational amplifier TL084 (b)
- Simplified equivalent circuit of integrated op amp tone control circuit (b)
- Simplified equivalent circuit of integrated op amp tone control circuit (a)
- Integrated op amp tone control circuit
- OCL power amplifier with integrated op amp driver
- Measurement amplifier circuit using programmable integrated operational amplifier
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
