Linear constant current source composed of integrated operational amplifier
Source: InternetPublisher:super_star Keywords: Constant current source integrated operational amplifier linear constant current Updated: 2021/03/12
![Linear <strong>constant current source</strong> circuit composed of <strong>integrated operational amplifier</strong>](http://www.eeworld.com.cn/circuit/upload/721cee5281a628c902df746024d2157e/3b2be30c557eab3fdc41e1de340c2cde.png)
The linear constant current source circuit composed of an integrated operational amplifier is composed as shown in the figure. Two operational amplifiers (one piece of 324) constitute the comparison amplification link, and the BG1 and BG2 transistors constitute the adjustment link. RL is the load resistance, RS is the sampling resistor, and RW is The circuit provides the reference voltage. Working principle: If Uin decreases due to power supply fluctuations and the load current decreases, the sampling voltage US will inevitably decrease, so that the difference between the sampling voltage and the reference voltage (US-Uref) will inevitably decrease. Since UIA is an inverting amplifier, its output voltage Ub = (R5/R4) × Ua will inevitably increase, so that the US can be raised back to its original stable value through the adjustment process, ensuring the voltage stability of US and thus making the current stable. . When Uin rises, the principle is the same as before. The circuit uses the closed-loop feedback system to make US drop to the original stable value, thereby making the current constant. Adjust RW and change Uref to make the current value continuously adjustable between 0 and 4A.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Driving circuit of switching power supply field effect tube
- Step-down power supply for driving relays
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Parallel DC regulated power supply circuit diagram
- Adjustable regulated power supply with current limiting protection
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- MAX1811 Lithium Battery Charger Production
- How to make a constant current source using an op amp circuit
- Linear constant current source composed of integrated operational amplifier
- Power circuit b composed of intelligent thyristor modules
- Power circuit a composed of intelligent thyristor modules
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Warm current power circuit a
- CF1 (CF2) DC power supply circuit
- Industrial four-way programmable controller power circuit
- Comparative circuit diagram of various VI conversion and constant current sources
- Circuit diagram for charging using external constant current source
