Equalizer (a) composed of TL084
Source: InternetPublisher:念念Brown Keywords: BSP potentiometer amplifier PERMIL Updated: 2021/06/11
It is a dual five-band graphic equalizer circuit composed of an integrated operational amplifier TL084. Now take the L channel as an example to analyze
its working principle. This circuit uses an adjustment potentiometer connected to the inverting and inverting input terminals of the op amp.
The principle is shown in Figure 4-35(a). Now compare and analyze: the operational amplifier Ai forms a common amplifier , and the five operational amplifiers A3 to Aii
form a balanced network with center frequencies of 100H, 330Hz, 1X7, 3.3kHz, and 10kfk respectively. Analog inductor. In
the circuit, C9.C14, C19.C25, C31 are equivalent to Cl; cll, C16, C21, C27, C33 are equivalent to Q; attenuation
resistors R14, ‰, ‰, R3z, R38 are equivalent to Ri; Rl5, Rzt , Ai, R33, R are equivalent to the feedback resistor R2.
In Figure 4-35 (a), five potentiometers RPi~RPs are connected between the non-inverting and inverting input terminals of the common amplifier. When
the sliding point of the potentiometer is upward When moving squarely, the fo component in the input signal is
divided by the series resonance network composed of Ri, analog inductance and cl. At the same time, the feedback coefficient of the amplifier circuit increases, the amplifier gain decreases, and fo is attenuated. When the potentiometer
's slide point moves downward, the opposite occurs, so fc is raised. When the sliding point of the potentiometer
is in the middle position
, the amplifier neither attenuates nor improves, and the amplifier is in a flat amplification state.
- TDA2009A power amplifier circuit
- Make a high-quality DAC board
- Making a Simple Tube FM Radio
- 6N5P tube direct-coupled single-ended amplifier
- LM4766 Dual 40W+40W Power Amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Dual power supply audio power amplifier circuit composed of LM3875
- High gain audio amplifier circuit composed of LM4818
- Horseshoe gallbladder preamplifier circuit
- Motor overcurrent protection circuit
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- Agricultural spraying and insecticide control circuit
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- collector amplitude modulation circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Motorcycle flash light circuit
- Digital stopwatch display circuit
