The second type of balancing circuit
Source: InternetPublisher:明天见 Keywords: Balance circuit potentiometer Updated: 2020/10/07
In the balancing circuit using the second connection method , its working principle is shown in Figure 1-96. When the potentiometer sliding arm moves to
the inverting input terminal "one" of lc, the parallel value of the resonant impedance B and the feedback resistor R is the smallest, so the feedback amount is the smallest and
the circuit gain is the highest, which is equivalent to the gain of o and its surrounding frequencies. promote. When the potentiometer sliding arm moves to the non-inverting input terminal "+" of LC , the parallel value of the
input attenuation resistor R'o of B and LC is minimum, so that the signal input voltage of fo and its surrounding rate
is minimum, and the gain is attenuated.
- Using TDA2822 to do direct coupler output experiment
- 18-inch large speaker
- Homemade multi-sound effects sound system
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Using Shuguang 350C tube to make tube amplifier
- Dual power supply audio power amplifier circuit composed of LM3875
- Bridge output audio power amplifier circuit composed of LM1876
- LMl876 is used to assist the audio power amplifier circuit
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- LM4819 high gain audio amplifier circuit
- Water dispenser double sheet control circuit
- Full wave rectification adjustable charging circuit
- Manual temperature control circuit 7
- Manual temperature control circuit 2
- Automatic light control lighting circuit three
- Intermittent cycle control start and stop circuit 7a
- Integrated digital volume potentiometer circuit
- Gentleman AM50 amplifier circuit
- Class A super power amplifier
- Darkroom exposure timing circuit (1)
