Equivalent circuit for treble boost
Source: InternetPublisher:无人共我 Keywords: Equivalent circuit BSP audio signal Updated: 2020/12/31
Adjusted to point D, the treble is boosted
(1) When only considering the effect of Vi on Vb and not considering the effect of Vo on Vb, the equivalent circuit is as shown in Figure 1-82 (a).
It shows that if the capacitive reactance to the high audio signal C4 is small, Vb will be large, and if the capacitive reactance to the low audio signal C4 is large, Vb will be small;
relatively, the high audio signal will be improved.
(2) Only consider the relationship between Vo and Vb If the effect of Vi on Vh is not considered, the equivalent circuit is shown in Figure 1-82 (b)
. At this time, since the resistance of Hu Yao is large and the resistance of R12 is small, the negative feedback effect can be ignored. When its comprehensive characteristics are adjusted
to point D, the high- frequency signal is enhanced, as shown in the curve in Figure 1-82 (c).
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Using TDA2822 to do direct coupler output experiment
- Field effect tube amplifier circuit with beautiful sound
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- Dual power supply audio power amplifier circuit using LM1875
- LM4902 differential input audio amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Analysis of rectifier circuit types and principles
- Egg warming circuit
- Rice mill circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Simple AGC circuit in transistor radio
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
