Attenuation-feedback tone control circuit
Source: InternetPublisher:奥特man123 Keywords: Tone control circuit BSP signal source Updated: 2020/08/01
The picture shows an attenuation feedback tone control circuit. There are both attenuation and feedback
effects in this tone control circuit
. Therefore, it is not easy to distinguish whether the high and low sounds are improved or attenuated. Next, we use the superposition theorem to
analyze the circuit.
The superposition theorem points out that in any linear circuit, the voltage of each branch can be regarded as
the algebraic sum of the voltages generated in the branch when each signal source acts separately .
Analyzing with Figure 1-79, the input signal voltage Vb of the base
can be seen as the result of two signal sources , that is, the voltage formed by the input signal voltage Vi on the base
and the output signal voltage vo pass through Negative feedback creates a voltage at the base .
- Share a mini piano circuit
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Echo Dot speaker intelligent control system solution
- How to adjust the bass and treble of CXA1005
- Field effect tube amplifier circuit with beautiful sound
- DIY 50W Gallstone Amplifier
- Homemade multi-sound effects sound system
- 6AS7 tube amplifier
- Using Shuguang 350C tube to make tube amplifier
- Protection circuit and maintenance of household audio power amplifier
- Excellent performance household inverter power supply circuit
- Ultrasonic blind pathfinder circuit
- Inpatient pager circuit
- Double detuned loop frequency discriminator circuit
- Diode square rate detection circuit
- Schiller oscillator circuit
- superheterodyne radio circuit
- High and low frequency signal generator circuit
- Three primary color display circuit
- Guest arrival signal recognition circuit
