Add amplifier before attenuation network
Source: InternetPublisher:李商隐身 Keywords: Amplifier network RC BSP Updated: 2020/03/12
From the previous analysis, we can know that adjusting RPi and Coral can make the RC attenuator boost or attenuate signals of various frequencies
. However, please note that the so-called boost and attenuation are for flat characteristics. Due to the addition
of the RC attenuation network, the flat characteristic as a benchmark is attenuated by about 20dB compared with that without the RC attenuation network. This
loss is usually compensated by adding an amplifier. The voltage gain of this amplifier should be 20dB (that is, the amplification is 0). Should
the amplifier used to compensate for the attenuation loss be added before or after the attenuation network ? Because if you attenuate first and then amplify
, the signal-to-noise ratio will deteriorate when a small signal is input, so it is often added in front of the attenuator, that is, amplify first and then attenuate, as shown
in the figure.
The volume control potentiometer RP3 should be placed in front of the amplifier to avoid When the volume is adjusted, the load on the RC attenuator
is caused to change.
- Using TDA2822 to do direct coupler output experiment
- Field effect tube amplifier circuit with beautiful sound
- A high-quality tube amplifier with 6P3P design
- Practical and high-performance preamplifier circuit
- Design and production of class AB headphone amplifier
- Installing a tube preamplifier in the power amplifier
- A very simple amplifier
- Minimum output noise/reduced output power circuit using LM4910
- LM4915 is used for dual-channel amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- electromagnetic field sensor
- Ultrasonic blind pathfinder circuit
- Pulse therapy circuit
- Crop anti-frost circuit
- Junction field effect transistor mixer circuit
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- Three primary color display circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (2)
