Differential input stage with separate feedback circuit and bias circuit
Source: InternetPublisher:spectrum Keywords: Bias circuit input resistor RF Updated: 2020/08/21
Using the circuit form shown in Figure 1-36, the feedback circuit and the bias circuit are separated, and Rfl is approximately 30fl. In order to ensure the amplification factor, R is set to lkflo , and a resistor R2 with the same resistance
as the base resistor R of the left tube is connected in series between the base of the right tube and Rtz , so that
R2=Rl≈30kfIO, so that the bias current on both sides can be consistent, and The input resistance does not decrease either.
- Echo Dot speaker intelligent control system solution
- The easy production of several top-quality tube preamplifiers
- Practical and high-performance preamplifier circuit
- Make the most beautiful sound with the least money
- Biliary duct 2A3C Class A amplifier
- Audio power amplifier circuit powered by a single power supply using LM1875
- Dual power supply audio power amplifier circuit composed of LM3875
- High gain audio amplifier circuit composed of LM4818
- Class A power amplifier circuit with an output power of 18W
- Single power supply audio power amplifier circuit composed of LM3875
- Three basic bias circuit structures c
- Several basic bias circuits for field effect transistors - voltage divider self-bias circuit
- Transistor reference basic bias circuit-voltage negative feedback type
- Input stage with bias current introduced by positive power supply
- Hushan 100J-01 power amplifier
- Bias circuit of complementary symmetrical OTL circuit
- RF Tuned Amplifier Circuit Diagram C
- Field effect transistor amplifier circuit diagram with external gate bias circuit
- Global CRFP-3 electric heating pot circuit diagram
- Hall element bias circuit
