General form of differential input
Source: InternetPublisher:子丑寅卯 Keywords: BSP ground amplifier transistor Updated: 2020/02/26
In an input circuit using a transistor as a differential input stage, the resistance Ri connected from the base of the left tube to ground and the resistance
R connected from the base of the right tube to output point n generally have the same value, as shown in Figure 1-34 As shown, since the output point D is very close to the ground potential,
the bias currents of the two tubes are basically the same. After removing q, Rn is directly connected to ground , and the bias resistance value of the right tube is approximately equal to Rfl. Considering
that there must be sufficient amplification and R is not too large, R fl is generally taken as 1 m, and the left tube bias resistor Ri is usually
30kn, so the bias current of the left and right tubes is obviously different, and the open-loop characteristics of the amplifier It must be bad. Especially when the differential output
is a double-ended output, the output voltage will differ too much, which
will have a negative impact on the subsequent stage. If the left tube is also changed to 1kfl,
of course the left and right bias currents can be consistent, but such a low input
resistance is difficult to match with the front stage, which increases the difficulty of production
. To solve this problem, the following methods can be adopted.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Using TDA2822 to do direct coupler output experiment
- Design and production of class AB headphone amplifier
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Make cheap speakers using waste circuit boards (TDA1013)
- Class A power amplifier circuit with an output power of 18W
- LMl876 is used to assist the audio power amplifier circuit
- LM4820-6 audio power amplifier circuit
- Differential input audio amplifier circuit composed of LM4904
- electromagnetic field sensor
- Fish pond oxygenation reminder circuit
- Straw returning to field crusher circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Domestic KD8041 integrated phase locked loop
- Diode balanced amplitude modulation circuit
- Schiller oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order band-pass filter circuit
- High and low frequency signal generator circuit
