Analysis of self-retained feedback of OCL power amplifier
Source: InternetPublisher:方世玉223 Keywords: Power amplifier OCL voltage follower Updated: 2020/06/19
The working principle of DC feedback is shown in Figure 1-31. In the circuit,
R7 is connected between the output terminal (midpoint when static) D and
the base of the differential input stage Vr. For static purposes, this is a full negative feedback circuit,
that is, a voltage follower . Its voltage amplification factor is 1. The output voltage
follows the change of the input voltage. As analyzed before, Vbl=VbZ=ov,
so the midpoint voltage VD= OV oWhen VD rises for some reason,
through the adjustment effect of negative feedback, VD will be automatically returned to
ovo
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Using TDA2822 to do direct coupler output experiment
- Practical and high-performance preamplifier circuit
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Design and production of NE5532+TDA1521 amplifier
- 6BX7 10W bile duct amplifier
- Stereo tube power amplifier
- 2W×2 power amplifier circuit using LM1877
- Typical OCL power amplifier circuit
- 80Wx2 high-fidelity power amplifier
- LM3886 BTL amplifier
- audio power circuit
- DC power amplifier with simple circuit
- Hushan 100J-01 power amplifier
- Two-stage difference amplifier OCL amplifier
- Production of high-quality active two-way constant current power amplifier 01
- Upper and lower symmetrical negative feedback mode field effect transistor power amplifier 02
- OCL quasi-complementary power amplifier circuit diagram
