DC power amplifier with simple circuit
Source: InternetPublisher:newlandmark Keywords: Amplifier BSP Updated: 2021/05/23
This circuit uses a very simple circuit structure, but its performance is very good. Its principle is shown in Figure 2-25.
This is a power amplifier circuit with fully complementary symmetry, double differential junction, complementary push-pull voltage amplification, and field effect tube complementary push-pull power amplifier output
. It has no feedback capacitor, so it is a DC power amplifier circuit.
The differential input stage uses a pair of integrated differential tubes 2SC1583 and 2SA798. Since the parameter
performance is more consistent, and the working characteristics can still be consistent when the temperature changes, it is beneficial to the operation of the whole machine. The stable
output stage uses a pair of field effect power output tubes 2SK134 and 2SJ49 with excellent performance, which makes the performance of the whole machine
very excellent.
R7, R and C2 form a negative feedback system, which determines the closed-loop gain of the whole machine.
In the circuit, the capacitors C3 and C4 connected across the c and B poles of VT3 and VT4 and the capacitor C2 connected in parallel to R
are phase compensation capacitors designed to suppress circuit oscillation. Among them, C and 0 connected between the BC electrodes of the transistor are called lead
compensation capacitors. C2 connected to the feedback resistor Ra is called the hysteresis compensation capacitor.
Adjust Sha' to adjust the bias voltage of the output tube, adjust RPi to adjust the output midpoint voltage, this machine is lOOnrA.
If a single tube is selected for the differential tube pair of this machine, it must be strictly matched according to the parameters of each tube to ensure the performance of the circuit .
Soil I_ _, one
- How to adjust the bass and treble of CXA1005
- TDA2009A power amplifier circuit
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- Design and production of class AB headphone amplifier
- Design and production of NE5532+TDA1521 amplifier
- Homemade multi-sound effects sound system
- A very simple amplifier
- Typical applications of optocouplers in audio amplifier circuits
- Dual power supply audio power amplifier circuit composed of LM3875
- Motor overcurrent protection circuit
- Electronic thermometer circuit
- Electronic anti-asthma circuit
- Mixer built with analog multipliers
- Simple AGC circuit in transistor radio
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Small current generator circuit
- Sine wave signal generator circuit
