Production of high-quality active two-way constant current power amplifier 01
Source: InternetPublisher:司马缸砸光 Keywords: constant current power amplifier phase shift network Updated: 2021/04/23
10. For an electronic crossover with good performance, in addition to the conventional indicators such as distortion, load, and impedance, it is also important to consider its attenuation rate. The rate increases
with the order of the crossover network . Generally speaking, the larger the attenuation rate, the better, which
can reduce the distortion caused by the mutual interference of treble and bass. However, the phase shift also increases with the order. Generally , the smaller the phase shift, the better. In summary, it is generally believed that the second-order frequency division is slightly better. Figure 9-7 shows the amplitude characteristics of
the second-order high-pass and low-pass filter networks . And the synthesized
curve mouth can be found from the figure that the synthesized curve is not a straight line, but produces a depression.
- How to measure short circuit and ground with a multimeter
- Multimeter with small capacitor test circuit
- New function added to MF-47D multimeter - infrared remote control detection
- Multi-speed current test circuit of transistor HFE
- A low-cost inductance meter consisting of a single IC
- Electric vehicle luminous voltmeter with undervoltage alarm
- An electronic load meter using LM324 operational amplifier as the main control device
- AC equivalent amplifier circuit
- Light Detection 4 to 20mA Current Transmitter Circuit
- Multimeter DC voltage measurement circuit
- Tube crossover balanced inverter circuit diagram
- Analysis of self-retained feedback of OCL power amplifier
- DC analysis of OTL power amplifier
- BTL amplifier using HA1392
- DC power amplifier with simple circuit
- Homemade high-performance four-dimensional surround sound amplifier 02
- QSC1300 power amplifier principle and maintenance
- "Strange trick" amplifier
- Simple 50W high-quality power amplifier 01
- HI-FI amplifier 01 made by STK4040x1
