70W power amplifier circuit
Source: InternetPublisher:风向西瓜 Keywords: Power amplifier circuit BSP output signal PLUSMN Updated: 2021/08/31
The operational amplifier stage of this circuit adopts the transistor voltage stabilization power supply method, and the voltage regulator tube provides the reference voltage
, and the power supply voltage is ±15V.
In the output stage of this circuit, in addition to the normal connection to R13 and R14, the emitters of VT3 and VT4 are also connected to
R1l and R12, and the other ends of Rl 1 and RI2 are grounded. The output signals are output from the collectors of VT and VT4 respectively.
This means that due to the addition of Rj l and Rl2, VT and VT4 form a common-emitter amplifier circuit, which has a
certain voltage amplification capability. This circuit is designed for 7 times.
Since the output stage has voltage amplification capability, the voltage output of the pre-stage does not need to be very high. This circuit requires that
the IC has an output voltage of 5v, which is 0 5V × 7-35V. In this way, the output power of the circuit can reach 70 Wo.
The circuit adjustment is relatively simple. You only need to adjust the island and Rlo so that the final quiescent current is between l0 and 20mA.
- Field effect tube amplifier circuit with beautiful sound
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Single-ended Class A amplifier using gallstone composite tube design
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- Audio power amplifier circuit powered by a single power supply using LM1875
- Dual power supply audio power amplifier circuit composed of LM3875
- Class A power amplifier circuit with an output power of 18W
- Multimedia Hi-Fi amplifier circuit
- Protection circuit and maintenance of household audio power amplifier
- Excellent performance household inverter power supply circuit
- Electronic thermometer circuit
- Rural vegetable greenhouse lighting circuit
- Agricultural small tractor lighting circuit
- base amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- Small current generator circuit
- Sine wave signal generator circuit
